Auto Doc - interesting read. One has to wonder how does someone get multiple plastic baggies in the fuel tank except by sabotage? I know friends who have pulled tee shirts and socks out of gasoline tanks in collector cars when restoring them.
Rev-B - also an interesting read. John Denver crashed and died when he ran out of fuel on the main tank. The kit builder put the fuel selector over the pilot's shoulder instead of the recommended lower position on the floor or wing root. Denver never did anything with that, surprising because his father was an Air Force officer who flew, so Denver grew up knowing risks of flying. I say that because my dad was a career USCG SARS pilot and officer, and I know the many stories of his experiences of how easily things can go south to the unsuspecting / unprepared. Denver's fuel was low when he took off, someway inebriated, telling the FBO that he had enough fuel with his reserves to make the short trip home. Well, the end result is that he was using vice grips on the fuel selector shaft for lack of a knob, and during the accident inspection, the FAA found a vice grip attached to a broken shaft, which the shaft was still in the main position - being out of fuel. When he ran out of fuel, most likely he reached back over his shoulder to switch to reserve and snapped the selector shaft. Fate is the Hunter. I like the idea of assuming 1/4 is E in the situation you had. Better safe than sorry.
To the OP. Heet is used on gasoline engines but not in diesel or 2-stroke. It is 100% methanol, which absorbs water. Several other brands use Isopropyl alcohol instead. If you have some 91% alcohol around, use a small amount - like a half cup etc., and it will act as a gas fuel line dryer if there is just a little water in the fuel. I ALWAYS start with the assumption that water is a high possibility culprit. It isn't the only one, but if the problem starts suddenly without mechanical noises, it is an inexpensive place to begin. On two strokes I usually assume that the diaphragm in the carb or fuel pump has been affected by ethanol or other chemicals in the fuel. I have had fixed jets unscrew and fall out - that one can be a puzzler.
