GAVolunteer
- Jun 28, 2013
- 14
- 38
Honda HRB2153SDA SN MZBA-6338804
Label on Transmission Spicer 20001-VE2-M100-M2 06-01-98
A friend gave this to me. He found it sitting out for the trash. Mower is in great shape. It appears to have sat unused for a long time. Carb was varnished with old gas, but cleaned up. Engine runs well.
The self-propelled did not work. The problem was the belt was not on the pulleys. In trying to put the belt back on, I noticed the shaft of the large pulley on the transmission had a whole lot of play in it. The pulley wobbles back and forth and I'm wondering if this is why the belt came off. In working on other mowers, I do not remember the pulley shaft having a lot of play in it, but I have not worked on many Hondas.
I took the transmission off the mower and removed the pulley. On the shaft where it goes into the transmission box, the shaft has an e-clip then a washer. On the other side of the shaft inside the transmission box is an angled pinion gear. All of the gears in the transmission appear to be in great shape.
I know that you cannot get parts for the transmission.
Questions:
1. Is the play in the transmission pulley shaft normal?
2. Is there a bushing in the hole of the transmission box that the pulley shaft goes through that could have worn causing the excessive play in the shaft?
3. Any ideas on how to fix?
4. Has anyone seen this situation before?
Any input and suggestions would be appreciated.
Thanks,
Robert
Questions:
Thanks,
Robert
