I have an early RT 5000 with MM46 mower deck. The drive to driven mower belts are un available. Honda also has a MM46K1 A that has replacement belts. If I purchase the mule (idler), driven pulleys and the brackets, bolts and washers etc that are different from the MM46 will those parts function with the MM46 deck which has a different part no from the MM46k1 A Deck?
Rather than converting all those parts, you may be able to find an aftermarket belt that will work okay.
The "V-Belt, Drive" here (part number 76182-752-831) shows a general part number "
LB-89" and in many cases, the last few digits = belt length in inches.
If you Google
LB-89 Belt, a number of non-Honda belts show up; it might be worth trying one of these vs. converting all the pulleys, brackets, etc.
