Honda or Toro
The rear axle has small seals at each end inside the bushings that wear out and all the dirt and water from the grass gets inside the bushings that cause this problem. You can't lube them because of the seals. But worth a try maybe after every time being used.
Toro plastic wheels are the same as all s/p mowers. To keep wheels from waring out fast just try to stay off the sidewalk or cement while using s/p drive. They will last longer. Cheaper to get new wheels then have to repair frozen bushing after 3 years with a Honda. Still both are good mowers.
The drive wheels on a Toro are different than those on other mowers. They use a different size drive gear, less teeth, smaller gear size. Because of that the gear on the wheels are larger. Because of this the alignment between the drive gear and wheel gear has a closer tolerance. Toro’s design for the axle alignment never took this into consideration and the result was that the metal drive gear chewed up the plastic wheel gear. I can’t count the number of wheels I had to replace in and out of warranty. Bulletins had you realign the bearing holders and check wheel axle bolts. Neither were successful at fixing the problem. As a mechanic and sales person my tongue was bleeding many times. This is the reason I never recommend purchasing a steel deck Toro mower, but I did sell many, even after telling customers my concerns, because of the price difference.
Disclaimer, I have been working for Toro dealerships since 1981 and was a strong supporter of all Toro equipment until the last 10 years. Now I pick and choose what I recommend.
Yes they do have metal drive gears, with plastic geared drive wheels. Mower blades blow stuff everywhere and a lot goes behind the plastic inner cover into drive system as you well now. Dirt, sand and plastic don't mix. With this being said you really can't stop parts from wearing out. Make's dealers happy to sell new wheels. Being a teacher is cool!
Replaced too many of them. The cause was not dirt or sand. Cause was wrong size gears and axle alignment.
I think Honda pulled out of the small mower market in 2024. Might find Toro parts and service easier to come by. I would keep both for a season and see which one I liked the most.
My Ace hardware now sells and services Toro.As well as a Stihl authorized dealer.I have both as well,but to know where I can get them serviced if need be.Hope you got some good info.I did.
