honda OHV LAWNMOWER
drno503
FOUND IN JUNK YARD CORD PULL OK OIL IN CRANKCASE DOSEN;T RUN
FIX,, REMOVE SPARK PLUG GOT SPARK ,,,YES
REMOVE CARB. DIRTY ,,,,,YES,,,, CLEAN CARB IN HOT SOAPY WATER REMOVE MAIN JET CLEAN WITH .05 WIRE
RE ASSEMBLE SPRAY WITH ETHER PULL CORD RUN YES
COMPLAINT,,,,, POOR PERFORMANCE IN HEAVE WET GRASS
TIMING NEEDS 2 B ADVANCED ???
timing is fixed elecrtonically and can not be changed.
Govenor is not working properly and is not opening the throttle far enough when the engine starts to slow down.
drno503
I TEND 2 AGREE WITH U THAT THE THROTTLE IS NOT OPENING FAR ENOUGH ,,,, BUT WHEN I OPEN THE THROTTLE MANUALLY WITH MY HAND IT DOSEN;T RESPOND WELL ENOUGH I AM LOOKING TO OPENING THE MAIN CARB JET .005 THE TIMING MODULE CAN BE MOVED BY SIMPLE MOUNTING CHANGE
Catherine
LawnWorld Support
:welcome:
I'm going to move this thread over to our Honda section for you.
