Compare GXV140 and GXV 160 you have difference 5HP and 5.5 HP and that was the spec more than 10 years ago .Now they dont made GXV 140 any more and look at the spec of GXV 160 on Honda now you will find out it have only 4.3 HP that because they try to reduce pollution ,lately HRC216 not for sale in CA anymore and the spec go back to 5.5 HP at 3600 rpm . To be honest I'm using HR215 and HR 195 for long time at close to 4000 rpm with out any problem
WARNING: California Prop 65 Info
SPECIFICATIONS
GXV160 | |
| Engine Type | Air-cooled 4-stroke OHV |
| Bore x Stroke | 68 X 45 mm |
| Displacement | 163 cm3 |
| Net Power Output* | 4.3 hp (3.2 kW) @ 3,600 rpm |
| Net Torque | 7.1 lb-ft (9.6 Nm) @ 2,500 rpm |
| PTO Shaft Rotation | Counterclockwise (from PTO shaft side) |
| Compression Ratio | 8.0:1 |
| Carburetor | Float Type |
| Ignition System | Transistorized magneto |
| Starting System | Recoil |
| Lubrication System | Splash |
| Governor System | Centrifugal Mechanical |
| Air Cleaner | Dual element |
| Oil Capacity | 0.69 US qt (0.65l) |
| Fuel Tank Capacity | 1.5 U.S. qts (1.4 liters) |
| Fuel | Unleaded 86 octane or higher |
| Dry Weight | 32 lb (14.5 kg) |
DIMENSIONS
GXV160 | |
| Length (min) | 16.3" (415mm) |
| Width (min) | 14.1" (359mm) |
| Height (min) | 13.9" (354mm) |
PTO
GXV160 |
