I have a Honda 21" self propelled walk behind mower, Model # HRR 2168 VKA. Serial # MZCG8420252.
bottom left hand corner is a triangle with ! in it.
Hit that then write Spam and the post name then send.
It sends an alert email to the moderators email.
You can do the same for advertising or other posts that you feel should not be here.
Why don't you mention the fact that the most likely cause is the rear drive axle cant turn back freely due to the incorrect bushing's they put on the Honda mowers that are doing this. Because that is the issue and Honda still has not owned up to this and it is not covered under warranty. Besides that many repair shops wont know that this is the likely issue because Honda never owned up to it and released a bulletin. So people are going to waste time and money bringing these mowers in for service only to find they cant be fixed or covered. You can also mention that if a the person is a bit handy and wrenches, he can take the back axle apart and take sand paper and go around both ends of the axle taking a slight bit of material off and re-lubricate everything, so those under sized bushings do not cause the mower to lock up when going in reverse anymore ever again.
We also know Honda has made all new back wheel height adjusters that have the correct sized bushings in them, which will fix this problem, however you could also just order those same improved bushings from a newer model Honda mower that fit on the axle of the mowers with this issue and it will correct the problem without having to spend the extra money to buy parts that aren't needed when all they need is the correct size bushing's.
Armed with that information everyone who is having this issue can fix it or explain what the problem is and have it fixed, which will make for a lot of happy honda customers who are using these mowers with this issue. Otherwise their left in the dark, become angry and frustrated and than will either get rid of the mower and buy a different brand.
The issue is the bushings are slightly to small and over time all the motion on that axle as well as moisture cause the axle to get a bit corroded or pitted and than the axle locks up on those bushings trying to pull back in reverse.
Honda should have just owned up to it, sent out the bulletin and either gave the option to send out the correct bushings to the homeowner, so they could fix it themselves or let the customer take it to dealers to have repaired and re-reimbursed the dealers. Considering how big Honda is and the profits they make every year, they could have done this and it would not have even put a dent in their profit margin's.
That slight drag from the rear wheels when pulling backwards is normal..I just finished replacing both adjusters and cleaning up the axels..and get same slight drag but the wheels do roll backwards.Drained the gas and oil so I could turn the mower over and attack it from the underside. I took everything a part thinking this wasn't rocket science and everything looked fine. Everything worked asside from the rear wheels locking whenever the mower was pulled backward. The wheels turned forward with a click but as soon as I reversed direction they froze.We didn't fix a thing but as long as I had it a part I sharpened the blades and bought a new belt for $5.90. We were focused on the transmission, the smartdrive, but it made no sense. We went on the internet and that seemed to where everyone else was focusing. It didn't make sense.Then we noticed the rear wheel cut height adjustment was seized to the wheel bearing. When we turned the adjustment the axle turned. Didn't compute. So if it's locked in position, so is the wheel. Change the height adjustment and the axle turns ever so slightly. We removed the wheels, the gears, and axle from the bearings. Cleaned everything and lubed the bearing well before reassembling. NOTE: Do not beat on the axle ends to get the axel out of the bearings, they are soft and the ends will mushroom on you. If that happens you will not be able to reinstall the washers and gears. Use a soft mallet or wooded block to protect the axle end. Oh yeah, you need a snap ring removal tool to remove the gears and REMEMBER WHAT DIRECTION THE GEARS GO ON and don't lose the slot key or spring. If you're thinking you should be doing something with the transmission, forget that. Your problem is in the rear wheel bearings. So the fix is cleaning out and lubricating the rear wheel bearings. Once we got the mower put back together, we added gas and oil and shared a look of hopeful anticipation. The mower wheels pulled back with a bit of drag but at least the wheels were turning. I started it up and the sharp blades cut thru really high grass like butter. The drive moves faster than I can walk and with the motor running it rolls back easily. I think it now works better than when I first got it in the fall of 2011. Hope this helps anyone whose having a problem with their rear wheels seizing up when pulling the mower in reverse.
My model: HRR2168VKA
What am I missing? On my Honda "masterpiece," it seems that the axle doesn't normally turn when pulling the mower backwards. If everything is working correctly, when pulling the mower backwards, the woodruff key doesn't catch on the inside of the pinion gear because of the way the gear is built. It is designed so that the key only engages the pinion gear when the drive axle is turning forward. If all of that is correct, then shouldn't the rear wheels just rotate freely as long as the woodruff key AND the pinion gear are installed correctly? What I also don't understand is that this mower's rear wheels never did roll backwards from the day it was new. The mower originally belonged to my son and he agrees that is the case. So are they lemons right out of the box?
Yep, and the main source of friction is the bushings.
So far having great results with the zerk fittings and keeping mine greased.
Looks like a great fix. Now that I have the JD I'm using the Honda as a trimmer. Thinking about selling the Honda and getting a simple high wheel push mower to do the trimming.
