there is different carburetor cleaning job. Dirt in gas and plugs high speed jet, quick blow out dirt job and run fine afterwords. Don't forget to repair the dirt problim. The other one is mower sat around for years with gas and water in carburetor. The carburetor is full of rust and varnish. That is where you have to let the carburetor set of days in cleaner and all the jets and small holes are plugged. This is the job where you have to take it apart more then once to get the engine running right. By all means this is new carburetor time at any price, that is if you can find one. Had this problem with a Honda Spree a while back they don't make replacement parts for this bike anymore.
