Chathamite
- Apr 8, 2013
- 3
- 17
My multimeter indicates while the mower is running, I am only getting 6.2 volts to the battery-not enough to charge the battery. I last fall replaced the starter assembly since it was failing to start the mower. Starter now works fine and if I remotely charge the battery, the battery fully charged shows 13.4 volts, more than enough to start the mower. I am concerned as to why I am only getting 6.3 volts to the battery while the mower is running. Any suggestions?
