Hi
I did initially think that it was the choke not functioning properly because it looks from the limited view that it wasn't opening and closing very much, however on closer inspection and taking the air filter off and putting the carb back on with the cables connected it definitely is functioning. I have tired the trick with the spark plug and I couldn't see a spark even in the shade but I shall try again tonight when it is dusk and hopefully I shall see better whether there is a spark or not. Failing that I think it will be a new spark plug. Thank you so much for your help with this matter and spending the time to contact me. Regards Julie
