I have a Honda lawnmower with a GCV160 engine that is 3-4 years old. My son borrowed the mower and after he was finished cleaned grass from underneath of the deck. In the process, gas spilled out and when he brought it back it would not start. Previously, it started on the first pull every time. I called a local repair shop who said to let the lawnmower sit for 2-3 days to dry out. Also, remove spark plug and air filter so they can dry out plus after spark plug is removed pull start rope 5-6 times to blow out any dirt in spark plug cavity. I let the mower sit but before I tried to start it I removed the air filter and carburetor to make sure it was dry too. When I re-assembled everything the engine was sputtering and black smoke coming out of the muffler. The engine continued to run however so I mowed the grass for about 45 minutes, stopping a few times to empty the grass catcher and restart the engine. The engine continued to sputter but run. The next day I took the carburetor off again and put it back on (with the metal arm forward) thinking I didn't assemble it properly the first time. This time the gas leaked out almost immediately after I opened the gas supply line. I removed the carburetor a couple of other times with the same result. Is their a simple fix for this or should I take it to the repair shop and cut my losses?
Thanks!
Pat
Thanks!
Pat
