So I bought my HRX217vka from HomeDepot about 5 years ago. It was the floor model and I got it for half price. Sadly, it never stared well from day one. I had to spray starter fluid by the air intake. When that ran out, I would just pour gasoline into the air filter (ya I know, :ashamed. Then last week I couldn't even start it using the old tricks.
So here's what I did over the last 3 days:
1) New spark plug
2) Took apart carb. Yucky, and 3 gaskets needed replacing, totally gummded up and a bit eaten away (prolly my pouring gas into the air filter). So I cleaned all the carb parts with CarbCleaner + compressed air, and hand made the three new gaskets using compressed fiber sheets. Piece o cake.
3) Changed oil
4) Cleaned out the gas tank and inline filter.
After doing those things, the mower started up smooth like butter on the first pull :biggrin:
But then I noticed a few hours later a small puddle of oil was spreading from under the front of the mower. After some searching, I found the location.
There is a slow drip coming from under the "OHC" (Overhead Cam) metal cover on the front of the engine. Now this is funny, because I DID remove the 4 screws that hold this on place, since I was planning on adjusting the valves. But when I got the 4 screws removed, that cover DID-NOT-BUDGE. Looking around the edges, it was completely glued on with something. I didn't try and force it, I just put the screws back on and decided not to mess with the valves.
So could I have caused the leak somehow? I'm also not sure but I suspect the leak might've been there before, but the deck was so gummed up with clippings that it was creating a seal, and possibly holding the oil in the clippings.
I don't think my unscrewing the OHC cover caused it, since that thing was so tight in place that it didn't budge. But the leak is definitely coming from there, center near the front. It looks like there's a little pressure lock piece from the cam cover there.
Obviously this thing is way out of warranty now (why oh why didn't I contact honda immediately after I bought this thing?) But do you guys think this is serious? Or should I just make sure and check the oil level before I run it each time? The leak seems to have slowed down, and the oil level is at the bottom end of the measuring stick.
Thanks!
1) New spark plug
3) Changed oil
Thanks!
