My 2011 Honda 217 is running rough. When I first start it , it spits out a puff of black smoke. I pulled the spark plug and it was black. I replaced the plug, but it still surges. Any ideas?
Black smoke, rough running and a black/sooty/fouled spark plug are generally symptoms of a rich (too much fuel or not enough air) condition.
1. Check the air filter. Replace it or clean it with compressed air.
2. Does your HRX have an automatic or manual choke? If the choke remains CLOSED after the engine has started, this will create a rich condition. Double-check and make sure the choke is working properly.
3. How old is the fuel? If more than 30 days old, drain tank and carb bowl, fill with fresh fuel.
