J Jeff T Member Joined Jun 5, 2019 Messages 42 Jun 15, 2019 #1 I swapped the handrails from another mower, cleaned the carb and the only issue is it won't shut off. If I push the assembly to make contact with the switch it shuts off but there is some resistance keeping the cable from pushing it off. Ideas??
J Jeff T Member Joined Jun 5, 2019 Messages 42 Jun 18, 2019 #2 Sprayed everything down with WD-40 and viola, it works!
H HRX Member Joined Jul 6, 2019 Messages 11 Jul 6, 2019 #3 Re adjust the cable. Is it auto or manual choke? If it is manual choke make sure it fully chokes ok? Maybe you need to check the stop switch.
