I just recently purchased a Honda self propelled mower Model-HRX217HXA and after purchasing it i had to buy a new carb and all the gaskets for it... It runs great now, but it is leaking gas but only when I am mowing sideways on a hill with the carb facing downward. IF i am level on ground it does not leak at all the gas is coming out of a small hole in the carb Hope that photo of the carb appears here so you can see where I mean I have never ran into this issue before so I do not know how to fix the problem .. the black arrow in the photo shows where the leak is coming from...any help would sure be appreciated... Thank you
