Honda HRR216VYA Surges when blades are not turned on.
semimechanicman
  • / Honda HRR216VYA Surges when blades are not turned on.
I have a Honda mower which works nice except it surges a lot when the blades are not on. When I turn the blades on the surging stops which is clear since the governor arm stops moving from left to right. Any idea of what’s going on? I cleaned the carb pretty thoroughly.
Scrubcadet10
Moderator
Staff member
idle circuit is still blocked, when you engage the blades, it runs on the main jet, which is why is smooths out.
