My mower stopped pulling as it should.
Sometimes it will pull fine and the next minute it won’t hardly pull at all. After a little investigation it appears the belt needs to be replaced, with the self propelled paddle pushed all the way down I can easily pull the belt around the pullies.
In the process of getting the belt off I mistakenly loosened the four bolts on the bottom of the transmission and fluid began leaking out.
What type of fluid goes in the transmission. It looks like thin motor oil. And how much?
Thanks in advance.
ETA- I believe I found the answer. 2.2oz of 10w-30 engine oil.
K5-K7 - 5.5oz
K8-K11 - 2.2oz
Thanks in advance.
K5-K7 - 5.5oz
K8-K11 - 2.2oz
