Honda HRR2168VKA issue and question
akrusnc
Issue - I am getting a stip of uncut grass. Like a mohawk. I believe my wheel is pushing down the grass when I go one direction and when I come back over it going the other way I don't believe my mower is pulling that grass back up to cut it. It is driving me nuts. Any suggestions? I have heard of going to a single non-muching blade but I was looking for someone who had this issue and was successful finding a cure.
Question - My lawn is very thick and my mower boggs down. Yes, even when I cut it every 3- 4 days. It helps if I bag the grass but if I try mulching it, it will stall for use. Is there an add on blower that I can add to keep the mower from stalling?
I would say the opposite. lower in back, higher in front. It allows the first cut higher and the second cut(at the rear of the deck) the lower cut
Cutting once in the front allowes the front tip of the blade to cut. And the rest of the blade to process. While lowering the rear makes the front tip cut the middle cut and the rear cut all the while the whole blade is still processing the grass.
