Honda HRR2167VXA with RotoStop for blades, blades will not engage
rodder98
  • / Honda HRR2167VXA with RotoStop for blades, blades will not engage
My serial number is MZCG-8261228. (Maybe a 2011 model) I replaced the old RotoStop cable, attempted to adjust cable to 2mm brake clearance with lever engaged, but have run out of cable adjustment. (Gap too wide) Now what can I do?
Also, I have no clearance between brake ring and the contact plate with lever not engaged. I want .08 gap. Is there an adjustment for this?
Engine runs fine, but I cannot engage the blades.
