OutdoorEnvy
- May 5, 2014
- 10
- 102
So I cleaned the above mentioned mower's carb and the jet was clogged shut so I gotta it cleaned out and the rest of it. And now the carb is flooding like crazy when I open up the fuel valve. I took it off and checked the float and it appears to be working normally to open and close. It's flooding out between the air cleaner holder. Could there be something else with the float that is the problem? It seems too much to be a bad gasket and it looked fine. I'm going to replace it anyways but this seems like a fuel shut off problem. Any help would be appreciated.
thanks
OE
thanks
OE
