From the photo, remove rod from lever B then pull rod (towards right on photo) choke should close, if so check to see if lever can go more to right on photo, it seems that it is at its MAX so therefore can't go anymore to be able to pull the choke on...!
Are there two holes in the plastic activator cam on top of the carb...? if so have you put the choke rod in the wrong hole in the plastic activator cam.
So unless you are going to take it into a shop, the only other way is to remove the rod, put throttle control lever in the choke position, put the choke closed on the carb and measure the distance between the two holes where the rod was and make a new rod to fit.
