HONDA HRD 536 LAWNMOWER TRANSMISSION PROBLEM. PLEASE HELP!!!
the_patriot
  • / HONDA HRD 536 LAWNMOWER TRANSMISSION PROBLEM. PLEASE HELP!!!
hello everyone,
i hope you can help me. i have taken on project to help fix a honda hrd 536 lawnmower. the problem was that it does not drive.
after taking it to a lawn mower mechanic i have been told that there is a problem with the transmission. the belt spins the pulley but does not drive the wheels. the pulley also comes completely out of the whole it sits in and the mechanic has told me that this should not be the case. the pulley does not looks broken or damaged. i have included pictures to help you help me.
any suggestions or accounts of your experiences with these types of problems and how they were overcome would be very much appreciated.
please let me know if i can provide any other information.
thank you in advance
EngineMan
Box needs to be taken apart to be sure but it look's if you have drop a circlip on the shaft, there is a member here who works for Honda, maybe he may help out with a part list, are the bearing(s) still OK..?
Look's like a HRD536 - Type: HXE Serial Number Start: MZBL8000001 - Serial Number End: MZBL8099999 I could be wrong..! can you post the numbers up.
the_patriot
20140701_004440.jpg20140701_004251.jpg20140630_172626.jpg20140630_172634.jpgHello,
Thank you for the info EngineMan. Very much appreciated. Now that you mention it there are 2 grooves going along the chamber where the pulley shaft goes in. Maybe some kind of clip or something is supposed to go there?
Are these the numbers you were talking about?
Thanks again everyone and await your reply
the_patriot
Uploaded the same pics
Here they are again showing the 2 grooves along the chamber. The grooves are parallel to each other if that helps
the_patriot
hello again guys,
another thing i remembered is that before i gave it to the mechanic it only use to move forwards and not backwards. apologies if i am making too many posts.
thanks
EngineMan
Your next set of photos show that below the oil seal, there is a groove, which looks original and is V shape, key ways are normally square, need a part list to be sure, so wait until someone here comes up with one.
robert@honda
hello everyone,
.View attachment 21828View attachment 21829View attachment 21830
Everything appears to be excessively worn. The shaft should have not come out of the transmission, but could if has worn beyond its service life. This mower is a non-US model, and I don't have any parts or service details to share, sorry. I will guess this transmission is similar if not identical to the ones used in USA models, and it does not have any internal parts that can be replaced. I would say it is (past) time to fit a new transmission.
Abe, are you in the USA? If not, what is your location? I can give you contact details for a Honda distributor (if you are outside the USA) who might be able to obtain a replacement transmission.
the_patriot
Hello,
Thank you for all your help. I live in west yorkshire, england, uk. Bad news about not being able to recon it but understandable. Please send me those details of a honda dealer. Everyones help has been much appreciated.
Thank you,
robert@honda
the_patriot
thanks for that. guess ill be going down the replacement transmission root. will a second hand one be okay?
