Hi , I have a Honda hrb476c all is well accept that sometimes not always while cutting the revs change notable so and it stops cutting but still drives on , if I lift the mower slightly the revs return and it continues to cut, this can happen at any point when I'm cutting, I'm hopping some one can explain what is napping and what is the cure, Thanks in advance.
