Honda HRA536 GXV160 engine
Winetu007
I have problem with this mower. As You see in the video when the clutch handle is in the OFF position and throttle control on high there is terible noise. When I pull the clutche handle (turn on blade) everythings sounds normal, mower normaly cutting. The problem will be with clutch or bent crankschaft?
Out of balance blades. Let us know what you find to be the culprit. Thanks Mark
I've found these folks to have lowest prices on OEM Honda Parts & ship fast to your door. All you need is model & serial numbers.
Usually the mowers with then BBC and have a clutch noise without the blade turning, and it goes away when engages usually indicates a bearing problem in the clutch. When disengaged the bearing turns on the crankshaft, but when engaged the bearing is stationary since it is turns with the blade
I think crankshaft is bent
