my mower is having several issues the first is when I try to engage the blade the engine cuts out. however if I slowly engage the blade it sort of bogs down and they engage along with the engine staying running.
second problem is a surging issue when I take it off of the choke and to the rabbit position.. a third issue in relation is that it doesn't seem to change idle speed when i turn it from rabbit to the turtle position and vise versa
any help would be appreciated thanks!
