Lawnnut
- Jul 5, 2024
- 1
Hi all!
I have a honda hr214 lawn mower. Since i have aquired its always ran away during startup. It’s to the point where i have to hold thr governor linkage to the carb and hold it manually to keep the rpms down for a while till i can let go and it keeps is low idle. In the past i have had a few times where its run away for 5 second. Ive gone thru the linkage and made sure everything it adjusted correctly as much as i know. I feel like rhe governor assembly inside the engine is bad because every time i start the mower the governor rod seems tight or stuck and I need to free it. Also it smokes on start up for a second or 2 which is a new thing. When the throttle lever is pushed form low to high the valve doesn’t move. What gives. Do you think it would need new rings and piston. I can try to upload a video to YouTube and add a link
What should I do. This mower has sedimental value to me and I want to keep it running.
