Honda harmony HRM215 problems
robert@honda
About to order parts and I see there are 3 part numbers for #15 gasket...
16221-ZG9-J60 SEE PART DETAILS - PRI; GASKET, CARBURETOR $0.98
16221-ZG9-T00 SEE PART DETAILS - PRI; GASKET, CARBURETOR $0.98
16221-ZH8-801 SEE PART DETAILS - PRI; GASKET, CARBURETOR $0.98
Not sure which one I need?
16221-ZH8-801 is the most current part number.
javjacob
I will go with that then. Honestly I cant imagine how they could be that much different. Thank you for all the help!
robert@honda
Part numbers change when suppliers change, materials change, packaging changes, or the design team actually makes a "real" change to the part.
We're here if you have any more issues. Best of luck getting it running smoothly soon.
javjacob
I got the parts in today and put the new carb and gaskets on along with a new air filter. It started right up and has a lot more power than before, I can now engage the blades instantly without the engine stalling like it had done for the past 8 years. Its hard to believe the carb was slowly robbing power for that many years. Last year I swore off ethanol after I found 2 gas stations somewhat close that sell non ethanol premium gas so that is all my small engines will run on from here on. I also see some local stores have the non ethanol gas in quart sized cans for a pretty penny if I ever had to resort to that. No more ethanol gas for my mowers though as I believe that is what caused my carb to slowly degrade over the years. I am very happy to have the Honda running like new again! :biggrin:
