New coil from Amazon came in today.
Got it installed. Gapped to 0.005"
It started with no issues.
Tomorrow I will cut the grass and see if it runs continuously over 20 minutes. Yard is about an acre.
What did you use to gap the coil? Let us know if the new coil does the trick.
I have a set of feeler gauges and just stuck the 0.005" between the flywheel and the new coil.
If you don't have one, you can use a thin business card.
I will cut the grass today.
I just bought this $10 coil to find out if the original coil was the culprit when it gets hot. Honda coil is about $80.
I want to keep this mower for a long time and will get the Honda part later when this cheap one craps out.:laughing:
It made it 35 minutes and then it died. LOL.
It has spark when I tested it.
Looks like this time it's fuel related because it starts then dies immediately.
Definitely heat related.
I am going to check the valve clearances.
Don't know what else to check after.
Did the cheap coil still produce spark after it got hot then died? At this point before messing with valve clearances try loosening the gas cap and running with the cap loose just to see if you have a gas cap vent issue.
So now it's a mission to get this one figured out! I would try a spark plug (verify that it's the correct plug) and if that doesn't fix it, a carburetor clean, or even even think about replacing the carb (mine are less than $15) Not worth the time and parts spent cleaning.
Does your carb have a drain on the bottom of the float bowl? The next time it quits you might crack that and see if there is A: fuel and B: water in the fuel. It doesn't take much. I have had my mower quit after a bit only to find water contaminated gas. I attributed that to the ethanol enriched gas I was using. A local gas station now has Recreational (ethanol free) fuel. I haven't had that problem since switching over.
