Honda GXV530
MDH
I have a John Deere which had a briggs motor in it when I acquired it but it was blown. I put a Honda gxv530 engine in it but I can't figure out the wiring. The plugs match up but the wiring is different. Every wiring diagram I can find has different colors than mine. My engine is probably 10 years old but it was crated and never used, basically new. Do they make a John Deere Z225 A mower with a Honda GVX530 engine and if so can you buy a wiring harness for it ?
robert@honda
Not sure about the Deere, but I can get you the correct wiring diagram for the Honda engine if you'll get the serial number off the side of the engine, just under the cylinder:
The serial number will be in the form of "GJAXX-1234567"
MDH
GJARM- 1027264
robert@honda
Here is the wiring diagram for your engine; FYI, you have a Honda GXV530 EXA2, which has a 12A charging coil.
MDH
This is my first time on this site so I'm not sure if I'm doing it right. It's a Honda GJARM-1027264
Thank You for the diagram I just printed it up and I'm heading to the garage and hope to make it work. Thanks again !!
