Honda GXV530 no spark.
Del@Midwest
Honda GXV530 with no spark. Tried new plugs, Gapped plugs, Removed stop wires from coils. Ran grounding jumper from grounding electrode on plugs directly to battery ground - no spark. Only way to see spark is to hold center electrode of plug nearly against a grounded bolt on the engine. Hard to imagine that both coils would be bad at the same time.
skippymud
Hi Del. You should be touching the spark plug's electrode to the engine block or something grounded to see spark. That's the way to check spark. I think you do you fire
Del@Midwest
I am, the grounding electrode. The center electrode should spark to the grounding electrode of the plug with the grounding electrode grounded and it does not, no matter the gap.
Del@Midwest
I am, the grounding electrode. The center electrode should spark to the grounding electrode of the plug with the grounding electrode grounded and it does not. I can stick a screwdriver in the boot of the coil and have to essentially touch ground with the shank of the screwdriver to see any spark. I think both coils are very weak. I've seen a lot hotter spark that what we're getting on other coils.
skippymud
Yea, sorry. I think I misunderstood the full context of your initial posting. So see pic. You're doing this, right? Just making sure b/c I don't want to misunderstand yet again LOL
Del@Midwest
Yes, that is correct. I also tried running an alligator clip jumper from the grounding electrode directly to the battery to no avail. Should serve the same purpose. Narrowed gap to .013 and won't spark. Didn't try any less.
skippymud
Hey Del
I am going through the very same problem by the way. I think that is why I am truly interested in yours
2-cycle Echo PB-403T backpack blower
OEM coil - no spark
Aftermark coil - no spark
Is this even possible. I've ordered another coil from a different MFR. We will see
Tiger Small Engine
Hey Del
OEM coil - no spark
Faulty ignition or on/off switch will cause no spark sometimes. Check for continuity and function.
Is this a sudden problem or are you trying to restore an old engine ?
Failure of both coils usually indicates a bad magnet in the flywheel or the flywheel just not spinning fast enough
