Hi all, would anyone know if the valve rocker arms from the GX engines are all the same? I have a broken one from my GXV340, and there appear to plenty available for the 160 and 200 engine, but not the 340. They look identical, but not too sure if it would be ok to use in the 340. Many thanks.
Here in the USA, American Honda Parts lists the rocker arm for the GXV340 is Honda Part Number 14431-ZE2-010
That same part is also used on the GX240, GX270, GX340, GX390, GX610, GX620, GX670 (these are all horizontal shaft models).
That same part is also used on the GXV270, GXV390, GXV610, GXV620, GXV670 (these are all vertical shaft models).
A different part number is assigned to the GX160, GXV160, GX200, and GXV200. I do not think the rocker arm from any of these smaller-displacement engines is compatible with your GXV340.
