Jwilson22071
- Feb 24, 2021
- 6
- 24
Have a Honda GX 390 (GCBCT- QA2). Pulled it apart to put new piston rings in it. Got everything back together. When I went to start it it runs for a 5 seconds and dies. Will start right back up, but dies again. Will only start with the choke on. I don't even have time to turn the choke of before it dies. Can keep it running somewhat with starter fluid. Had a new carb on it so I pulled it back off and replaced with the same one that came with it- same result. Here is what I've done so far-
1. Changed carbs and checked all gaskets
2. Owner told me he had trouble with governor before so I changed governor gear and shaft. 3. Cleaned out fuel tank and put new fuel line on. Got good flow all the way thru the bowl on carb.
4. Checked valve lash several times. Engine starts really easy, just will not stay running. I can kinda keep it running if I hold the carb shut at idle but cannot open the choke. Seems like I'm getting to much air but it has new gaskets and insulators.
Can the coil be doing this? I'm not to familiar with these 4 post coils I believe they are called. Its the coil with the plug on it. I started it with the switch plugged in , then i unplugged the switch ( checking the switch)and put the red and black wire together. Would not start unless I did this. Oil sensor wire is unplugged. The engine is on my lift do I need to ground the block somehow with this different coil? I'm lost any help would be appreciated. Thank you
