- May 6, 2010
- Threads
- 51
- 11,412
This engine mounted on a SxS will only idle if on full choke. Runs fine at full throttle, but immediately dies if even slightly taken off choke. Have adusted valve clearances, replaced spark plug, checked compression which is 95 and is within range for this engine. Have replaced carb, all intake gaskets, and the isolator with new gaskets. Tried an alternate fuel source with no change.
