Honda GX160 Mystery Engine
jjdc
I have a GX 160 Honda on a Mikasa plate compactor, the numbers stamped into the block do not match any Honda ID list I can find. I want to order the correct rings and piston for a Honda GX160-E1 with a vin/ serial #GCBT-1681677, Type SMXE. These are the numbers stamped into the engine block. However I can't find any site that lists these numbers "exactly" such as Honda, E replacement Parts, Mikasa ,Jacks, etcetera. Any body out that can point me in the right direction?
mechanic mark
Scrubcadet10
Moderator
Staff member
Could you post a picture of the numbers as well... if accessible...
