robert@honda
So I would need 2 x 21521-VB5-801? It is not a bearing, rather a bushing?
Description says it is a bushing...shop manual does not provide a spec or service limit, but video seems to verify worn bushings, but I can't say for 100% certainty.
and 2 x 91205-VB5-801 oil seals?
Probably, as they are likely the original seals. There are many other seals on the input and axle shaft, and if it was me, and I was rebuilding the trans., I'd put in all new ones for sure, to head off any possible leaks in the future.
You should get a shop manual if digging into the trans. It's not complex, but can save a lot of frustration, especially when you are doing a full-on restore/overall on a machine like this. Honda sells paper copies online direct ($35, free shipping)
Amazon: Honda-HRA216-HRC215-HRC216-Service Manual
eBay: Honda-HRA216-HRC215-HRC216-Service Manual
