I have a Troy-Bilt 21" Push Mower with Honda 160 cc OHC, Autonatic Return choke system.
I drained the gas last fall, and ran it dry. I changed the oil and cleaned the Air filter.
When I started it this Spring, it has a noticeable Surge, as though the Hi Jet needs adjusted.
But I can't find any adjustments.
It's the same with the Filter removed,
and in any Choke position.
Thanks for any help,
Nevin
Nevin
