I posted these pics on TBN in the Front Porch forum, I do a lot of vinyl siding/soffit work on the side and being too cheap to buy a ready made sliding compound miter saw, I made my own saw to use. The first pic shows an older 2 hp Craftman saw with the lower blade guard removed, there are alumimum U-channels bolted to the saw baseplate and the tracks are from a stainless steel cabinet I found in the scrap pile. It will crosscut 22 inches at 90 degrees and if you hold something at an angle it will easily cut most angles up to 45 degrees up to a foot across in the siding, etc.
