How to remove clutch from shaft I see it supposed to turn to the right to remove
C covse Forum Newbie Joined Dec 18, 2023 Threads 1 Messages 1 Dec 18, 2023 / Homelite 1989 240 chainsaw #1 How to remove clutch from shaft I see it supposed to turn to the right to remove
dougand3 Well-Known Member Joined Mar 10, 2012 Threads 12 Messages 455 Dec 18, 2023 / Homelite 1989 240 chainsaw #2 Remove spark plug. Rotate crankshaft till piston is coming up. Stuff some rope on top of piston. Unscrew clutch CW.
