Repairs Home Owner
Brad Locke
I have a Craftsman Lawn Tractor Model # 917.28852,that creeps Forward or Reverse when the shift lever is in neutral. How do you make an adjustment to prevent this?
You are going to have to remove the deck and get a good look at the drive belt and pulleys. Something is not releasing and/or worn. My guess the idler arm is not fully releasing or a bad pulley
Homer1
Is it hydrostatic? I didn't look it up, if so there will be an adjustment procedure to kick it into full neutral. My John Deere creeps also, I've never repaired it. If you can find a manual you should find the procedure.
Brad Locke
Good Answer,I have since removed the mower deck.I checked all the moving parts,and springs,i also checked the belt adjuster nut,for proper tension prior to removing the deck. This was driving me crazy,until i got a brain storm. I went to my neighbor,and asked him if i could try the new belt on his tractor. He has the same make and model,with a 42" deck. He was kind enough to let me try this,guess what,the new belt came up short on his mower also. The new belt was supposed to be a 42" belt as stated on the package,but it was mislabeled. It Is odd that Quality Assurance,didn't check this belt prior to selling it to the merchant. I'am not sure where this belt was manufactured,if this was from China,they haven't a Quality Assurance program.What they make in China is what you get,without testing or proper labeling.Thank You,for your suggestion. Yours Truly,Brad Locke
