Brad Locke
- Aug 6, 2015
- 2
I have a Craftsman Lawn Tractor Model # 917.28852,that creeps Forward or Reverse when the shift lever is in neutral. How do you make an adjustment to prevent this?
You are going to have to remove the deck and get a good look at the drive belt and pulleys. Something is not releasing and/or worn. My guess the idler arm is not fully releasing or a bad pulley
