Need some advice... I replaced the starter ring gear on my rider mower's flywheel and when I was putting the flywheel back on, I had to drill out one of the flywheel puller bolts because it snapped off during removal. When I drilled out the hole in the flywheel it went through the top of the engine block, unbeknownst to me. So I started it and did a couple laps and then it started smoking. I took the flywheel back off to see if the seal was leaking and that's when I discovered the hole I accidentally drilled through the top of the engine.
I think I can keep this engine alive for a few more years if I plug this hole. Should I tap and put a short bolt into the hole, JB weld or aluminum solder?
Engine internals all look good - nothing bent, broken or thrown. Any advice or suggestions would be appreciated!
Engine is a 1995 Briggs & Stratton (Craftsman) 19HP I/C Gold Twin
