- Sep 24, 2017
- 265
- 6,627
working on this 10 horse Tecumish....
Sat for years without starting. got it running. rebuilt carb. (needle and seat), float adjusted properly.
it runs good but has a pretty bad miss about every one to two seconds, plugs aren't fouling, and don't look lean, the burn looks good. The problem doesn't go away if i add choke.
verified good and constant fuel flow to carb( i've tried the original rebuilt carb, and put a known good HM100 Aftermarket carb on it, problem persisted), air filter is new.
Its a little finicky on the start too.
I have constant blue spark in my glow tester and the tester with 1/4" gap. Fuel is my non ethanol. fresh. i've tried 3 different plugs, Champion and NGK. Flywheel key is not sheared in the slightest.
I think my next step will be to check the valve clearance. I'm unsure of the hours on this unit.
