Hit stump, now Mower won’t start. Put new flywheel key in, have spark, sprayed starter fluid in spark plug hole and no attempt to start, PTO switch is pushed in, motor will not turn over if I pull the switch out, piston moves, bottom, pulley moves. Any suggestions? LT1042 model number 13BX11CG709442-3535. Serial number oneF035H20390.
