Boudreaux In Eunice La.
- Jul 22, 2017
- 21
- 2,154
No AF the flywheel can stay on..... Only the sump cover needs to come off to check every thing.........
Undo the 2 bolts holding the intake manifold on and a flip of the wrist will take the rod and spring off..... Take a pic of that where it goes to the control area.......
You will need to take the cable or cables off for the throttle and choke..... Mark with a sharpie on the cable where it goes in the clamp..... Both if needed...
Engine will come out with nothing attached like that..... Assuming you have the gas lines off........
I think I forgot to say something, but I think we got you on the right track ~!~!
Let us know Mon Ami ~!~!
