I hit a large rock that bent the blade and put a tear in the shroud of my Craftsman Bob Villa self propelled.
When I tried starting it, it sputtered and smoke pours out of the exhaust. Any ideas ? Thanks
Probably sheared the flywheel key which aligns the crank to the flywheel for proper timing.
Not sure about the smoke though....
Post some pics of the damage if you can, along with Engine model number
Tip the mower with the air filter on the high side to prevent that. With the spark plug disconnected and the bail tied down rotate the blade and and watch for a wobble indicating a bent shaft. The mower may not be worth fixing if this is the case.
Mowers should always be tipped head side up.
As just about all US made mowers mount the engine front - back , head forward then the best way to tip them is handlebar down
A lot of them will actually sit on the catcher flap quite happily depending upon where the bars hinge.
