If this is one of the older Snappers, then I agree the blade tip speed seems too slow. I do also agree that you should either find out or calculate your factory blade speed. The blade tip speed should stay below 19,000 fpm for safety reasons. Once you know your current blade tip speed, then calculate the percent difference between factory and 19,000 fpm. Take that percent difference and subtract it from 100 to get the relative size difference between the factory pulley and a new pulley. Multiply that number with the size of the factory pulley to get the new pulley size. If the new size falls between two available pulleys, then go with the larger one. Also, keep in mind if the new pulley is considerably smaller than the factory pulley, then your engine may not have enough hp to spin the blade at that new speed.
