Export thread
Hi
#1
Mbc
Mbc
My first post: I bought a new Husqvarna rz2346 last spring. Thinking it would stripe? But it didn't ! So every sense I've been trying to build a striper that works!
#2
lawn mower fanatic
lawn mower fanatic
:welcome: Hello! Read this thread....there are any different types of lawn stripers you can make: http://www.lawnmowerforum.com/comme...ng/13202-different-lawn-striping-systems.html :thumbsup:
Any questions? Just ask. :smile:
#3
Mbc
Mbc
Lol I've tried rubber flap,broom,PVC,chains,and my last I just finished after my grass turns brown is a roller! I think it might do pretty good? The best so far was the chains... Thanks for the thread
#4
TaskForceLawnCare
TaskForceLawnCare
How high is your deck, most mowers need to be at least 3 1/2"s or higher to get a nice defined stripe
#5
Mbc
Mbc
Its on the highest setting I think it measured 3 1/2
#6
TaskForceLawnCare
TaskForceLawnCare
Check out the toro or honda stripe kit they're rollers and will fit about any push mower i don't use them but a lot of guys on here say they have good results
#7
lawn mower fanatic
lawn mower fanatic
He has a rider. Ones that you buy can be pretty expensive! :confused2: Lawn Striping Kit | Yard Roller | Lawn Striper
#8
Mbc
Mbc
If I knew how to send a picture I could show ya the one I been workin on?
#9
lawn mower fanatic
lawn mower fanatic
If you are using the main website, check out post #3: http://www.lawnmowerforum.com/site-...sing-website-watch-these-video-tutorials.html :smile:
#10
Mbc
Mbc
I think I finally figured it out?
Mbc
Mbc
Here's what it done on my brown yard....
lawn mower fanatic
lawn mower fanatic
Maybe when your grass is green it would do better. :thumbsup:
#13
L
LoCo86
Not too bad considering the grass is going dormant. I see you were still able to pull off a diamond pattern. Personally I stick with just mowing two directions. If you mow you're yard a different way every time it just makes the yard look too busy. Just my opinion.
#14
Mbc
Mbc
Thanks for the feed back. I'm new at the striping game:) I've just been try to see if I could duplicate the differant patterns that I have seen?
#15
wjjones
wjjones
Welcome to the Forum!..Mbc..
