Fuel HHR2162 starts briefly want run
astewart
i have a HHR2162TDA mower. will not start and run continous. will run briefly with gas poured down spark plug hole.
javjacob
I would bet your carb is gunked up. Also check your air filter. The 10% ethanol they put in almost all gas now is very hard on carburetors and fuel systems. After you get it straightened out check out pure-gas.org to find a close by gas station that sells non ethanol gas.
mechanic mark
Honda Power Equipment HRR216K2 TDAA CARBURETOR | CyclePartsNation Honda Parts Nation just sign in or register will not cost a dime, have all numbers from mower & engine, order parts online, best prices I've found, these folks are fast, will ship UPS to your door. Do not forget new gaskets etc. when ordering, if you have questions you can call or send them a message, example: which carburetor do I need when several are listed?
