Heres an original, String trimmer won't start
Galaxy24
Running like a champ! Thanks all for your suggestions and input. Ended up doing the following: 1)replacing spark plug and adjusting the gap, 2)cleaning the spark arrestor, 3) lubricating throttle cable, 4)rebuilding carb, 5)replaced gas lines, 6)cleaned fuel tank. Not all work was required to get it running again, but wouldn't hurt either. I believe the problem was bad fuel. The gas lines were corroded which lead to my carb problems I'm sure. Thanks again!
Parkmower
Nice! You took care of everything so you'll be set for a while to come.
Galaxy24
Hope so. It was a good and fun learning experience.
