denthefish
- Apr 21, 2017
- 3
- 11
Hi Help!!! --- I have a 2000ish DYT 4000 18.5 intek - It will run about 10 minutes just fine - then starts to sputter almost stall and puffs white smoke like an Indian smoke signal ---- flipping the throttle up and down I can get it to run but will happen again and again -- I can let it idle all day - no issues - I replaced/did the following
air filter's clean - tried running with gas cap off -- new fuel filter --- new fuel -- fuel shut off valve - gas line not collapsed -- new plug - cleaned the carb - changed the head gasket - adjusted valves twice - changed oil and filter - new coil - no mouse nests - fuel pump pumps good with hose off - - vacuum to fuel pump clear - just ordered a new carburetor ( will put on this week)
What am I missing ????
